Heat Transfer a Different Elevations
When a heater is installed at a higher elevation than sea level does it take more or less gas to heat the bath
RE: Heat Transfer a Different Elevations
-Plasmech
Mechanical Engineer, Plastics Industry
TTFN
-Plasmech
Higher elevations will require more gas to heat the bath because heat transfer is lower.
Doug.
