What absolute pressure does a thermos lining have?
Title says it all.  What absolute pressure is attained in a Thermos (TM) vacuum jacket?
-Plasmech
Mechanical Engineer, Plastics Industry
RE: What absolute pressure does a thermos lining have?
Well, according to http://www.popedewars.com/labgrade.html
laboratory Dewar flasks are in the neighborhood of 10-5torr
I suspect that a run-of-the-mill Thermos for keeping your soup hot wouldn't bother to have such a good vacuum - a diffusion pump is needed to get down that low.
A decent mechanical vacuum pump could probably pull something like 10-3torr.  I'd imagine a Thermos is in that range.
From Google:
maximum pressure of a thermos bottle lining: 0.001 torr
typical: 10-6 torr.
