View orientation in Macro
I'm trying to switch to a predefined view in a part before the body of the macro executes.  Here is the start of the macro.
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
boolstatus = Part.Extension.SelectByID2("Sketch2", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Part.FeatureManager.FeatureExtrusion2 True, False, False, 0, 0, 0.1524, 0.01, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, 1, 1, 1, 0, 0, False
Part.SelectionManager.EnableContourSelection = 0
I'm using this command
Part.ShowNamedView2 "LogoView3", -1
I've placed this directly after Set SelMgr, but the macro reverts back to another view.  I then place this after the creation of the first body and it switches views.  My question is how can I have the view switch before I start creating bodies?
Thanks.
RE: View orientation in Macro
It looks like this macro was generated by the recorder.  The issue is probably that when you create your first extrusion feature in a part, the display automatically reorients to show an isometric type view of the extrusion.  There may be a way to create the extrude feature in a different way that doesn't do the reorientation.  However, what's the problem with putting your named view orientation after the creation of the first feature?
-handleman, CSWP (The new, easy test)
I'm trying to capture the macro events in a movie and would like the entire macro to run at the predefined view.
handleman,
I love the new signature, I thought of doing the same thing.
-Dustin
Professional Engineer
Certified SolidWorks Professional
If all you care about is the movie, just manually create some extrusion somewhere out off the screen, then run your macro.
Oh, and thanks, Dustin!  smile  It just doesn't feel right not qualifying the "CSWP" when some people took the test back when it really meant something.
