Laundry wastewater surfactant reduction
Can any tell me how to reduce the surfactants from a laundry waste stream.  The FDEP has a contamination limit at 2 mg/l as a residual in the soil.  The treatment process now is aeration and filtration and the concentration runs between 250-500.  The wastewater is disposed in a typical subsurface drainfield.  Am I wrong in arguing that the detergents are biodegradable.  I am testing an additive (basically grease)  and seeing some reduction (50%).  Maybe just increase the dose?  Seems kind of odd to add grease to waste water but what the heck.  Any help would be appreciated.
RE: Laundry wastewater surfactant reduction
The typical activated sludge process will remove the surfactants. The surfactants are biodegradeable.
Aeration alone is not going to do much.
Investigate the intallation cost of a package treatment plant.
Are there small package "off the shelf" options for activated sludge treatment?  This plant sees 8000 gpd max.
