russian bath design
russian bath design
Has anyone designed a russian bath? We are conflicted as to whether or not to recirculate the hot air within the room with minimum outside air or to use 100% outside air and heat it all up to avoid odor problems. We are hoping a voice of experiance can let us know what has worked for them in the past. - Thanks
RE: russian bath design
How many people are in there? Is this a public bath?
As a western capitalist I am ignorant of the customs of the Russians.
This person seems to be knowledgeable in this matter.
Like all engineers, given enough time and money I could apply the rules of science and design such a building but it may very well be easier if you can find someone with experience designing exactly what you want.
The first question you need to think about is what fuel is available, gas, electric, or wood, also what type of wood?, Different species have different fuel values.
Also where is the bath building located, what is the design temperature difference from inside to outside.
How well insulated is the proposed building?
How tight are the doors and windows, will there be a lot of infiltration?
from Russian sites and translate to English
