solidworks 2007 realview with nvidia 3450
Hello experts, I have a solidworks 2007 sp0.0 running on winxp cpu quad q6600 graphic card quadro fx 3450 with the certified solidworks driver. but... the realview icon is not grey but I can not choose it, no matter how many times I press it it does not checked. the card is set on solidworks settings and also the system options menu always makes the solid to close.
pleae help me! thanks
RE: solidworks 2007 realview with nvidia 3450
Check that the Use Software OpenGL setting has not been selected in Tools > Options > System Options > Performance.
cheers
thank you very much for the fast reply, but the option to activate the open gl is there (not shaded) but when I push the golden ball it pop back like I did not press it. the use softwear gl is not selected. could it be the tv card I have??? I am out of ideas... and again thank you guys!
If at all possible upgrade to a later service pack for 2007.  I do not know if it will fix your problem with real view, but it will save you from a lot of other problems.
Eric
