Delta Connected Capacitor Bank
I am installing an electronic trip unit on a 480 volt Circuit Breaker that is protecting a 240 KVAR capacitor bank. The cap bank is made up of 12 modules. Each 20KVAR module consists of 3 delta connected capacitors (each cap is 6.66 KVAR). The substation is a typical 1500KVA solidly grounded industrial substation.
Is there any guidance on what my short time delay and instantaneous settings should be to avoid a false trip when the bank is energized?
Also, what amount of current unbalance would you accept before you trip the breaker?
RE: Delta Connected Capacitor Bank
