Antenna Installation Stress Calculation
I am looking for a good book or other way to learn about stress calculations for aircraft antenna installation and other (simple) structure modifications (instrument panels, bracket and racks for avionics equipment,...)
I am working as an Avionics Engineer and I am keen to also learn the structural side of various modifications.
Thanx,
Michael
Thanx,
Michael
RE: Antenna Installation Stress Calculation
issues ...
rigidity of the support structure (vibration of the antenna),
ground handling loads (usually flight inertia and aerodynamic loads are very small),
damage tolerance (external doubler affecting inspection, external doubler causing load transfer that is usually the critical fatigue issue)
niu is a good textbook, i like bruhn's very practical approach but alot of his methods are showing their age (we have much more computing capability at our finger tips than he did !).
personally i'd avoid AC43-13
good luck
