IGBT bare die and FRD diode die sources
If some of you who know a reliable bare die source (IGBT and fast recovery diode), could you please let me know. Many thanks. I have contacted with Mintech, ditech, semidice, they seemed not willing to do business with us since our company is not a large company.
RE: IGBT bare die and FRD diode die sources
I think you're going to find that as a standard practice.  Producing dice is not a cheap venture, requiring some pretty pricey equipment with fast devaluation times (particularly when it seems we're cutting feature size by 5% every month).  What quantities are you talking about?
Dan - Owner
http://www.Hi-TecDesigns.com
The quantity for each type of bare die is about 5,000/month. If you have some good sources, please let me know.
I'm surprised that Semidice won't talk to you.  5000/month is a fairly large number; we've purchased less than 1000 from them before, but that was a Loooong time ago.  You might try talking to the manufacturer's rep and see if they help out in some way.
TTFN
Oh, I thought you were wanting a few hundred/month... as IR said, a few thousand/month should be acceptable for the smaller factory shops, particularly for something as simple as  transistors and diodes.  It's only a handful of processing steps, so they might even be able to process extra wafers at the end of a major run.  I've never worked with SemiDice, but I'm surprised you haven't found anyone willing to work with those numbers.
Dan - Owner
