Dimensioning Scheme
Dimensioning Scheme
At this time when I have a dimension where the minimum value is on the left side and the maximum value is on the right, I would like to change it to where the maximum value is over the minimum value. I know this can be probably changed in the drawing setup file but I don't know where the command is.
Currently, my dimensions look like this:
15.991-15.994
And I would like to have the dimension look like this:
15.994
15.991
How can I change this setting?
Thanks for your help.
15.991-15.994
15.994
15.991
RE: Dimensioning Scheme
symmetric_tol_display_standard std_asme
I tried modifying the symmetric_tol_display_standard options and it didn't seem to change anything. When the tolerance was shown as 15.993+/-.002, those settings did make a change; however, when the tolerance was displayed as 15.991-15.995, the settings did not change the display.
Do you have other suggestions I can try?
