Component array
Component array
Component array
I wonder if you could help me. When I create an array of components, it wont let me to delete those components, when I dont need them. Do you know, how to get rid of that?
Vit
RE: Component array
Try this Vit: Assemblies / Edit Component Array...
Gary Ashby
Designer
UG/NX V8 Thru NX5
SolidWorks 2007
AutoCAD 2002 & 2008
RE: Component array
Gets me about every time as well, Vit.  I feel it's a poor location for an Array command to be put, but I understand the logic of placing it on the Assemblies pulldown.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
RE: Component array
Vit,
You have to delete the component array to delete the components, and also if the array was based on mating conditions then you should delete the component array if you choose to delete the mating condition. Otherwise you get orphaned and basically dead component arrays left hanging around in the file. An annoying piece of housekeeping for some. I'd encourage you to test for yourself now that you know where the commands are, because my comments are based largely on older versions of NX and I haven't had the chance at this time to re-check in NX-5
Best Regards
Hudson
