LPG HIGH RISE BLG.
LPG HIGH RISE BLG.
LPG HIGH RISE BLG.
  I need to design a LPG system for a high rise bldg.  The owner request that any apartment use gas meter.  Its my first time design a LPG with gas meter in each apartment.  The building has 90 floor story, each story has 3mts high.  Could you help me with a diagram for the riser including the meter, the meters can be installed in the technnical floor every 20 story, like a meter bank, then each meter come up or down to the apartments.
RE: LPG HIGH RISE BLG.
If you have to ask a question like this, “Could you help me with a diagram for the riser including the meter,” should you be doing this work without experienced supervision?  Seems like this should be a question for you supervisor, such that both you and the supervisor understands your depth of knowledge.  This should enable him/her to provide you with the appropriate help and design review to match your experience.
