question on ABS piping
I am working on the upgrade of a water treatment plant, where piping is made in ABS. We have valves with spigots with an outer diameter of 73.1 mm, which corresponds to 2 1/2" ANSI pipe. Do you know of a supplier of fittings and adaptors for ABS piping in ANSI Standard?
RE: question on ABS piping
This is the ABS used in Europe, Middle East and Asia. It may be different to the grades used in the USA.
http
