How to determine Fa and Fv?
There is a Site Class F site (has liquefaction settlement).
The proposed building meet ASCE 7- 20.3.1 exception. In the exception says "Rather, a site class is permited to be determined in accordance with Section 20.3 and the corresponding values of Fa and Fv determined from Tables 11.4-1 and 11.4-2"
What does it means, and in this case how to determine Fa and Fv?
Thank you.
Thank you.
RE: How to determine Fa and Fv?
once the site class has been determined, you pull Fa and Fv from the table based on Ss and S1 along with the site class.
Therefore, I use Site Class D, and get Fa Fv value based on Site Class D.
City Correction Letter says: Per CBC, all site has liquefaction settlement should be classified as "F"
Therefore, I get confused....
or
Should I class the site as "F", and then use Fa Fv value for site class D?
Thank you.
try the usgs link
http://ear
also try
FEMA454
http://www.fema.gov/library/viewRecord.do?id=2418
FEMA451B & 451 & NEHRP recommendations
http://www.bssconline.org/
