Determining whether Galvanized or Stainless Steel
Are there any tests that can be performed to determine if our conduit connections are galvanized or stainless steel?
If so how do I go about testing the material.
RE: Determining whether Galvanized or Stainless Steel
If the connections are magnetic, they could be a ferritic stainless steel or galvanized. In this case, remove one and visually look to see if it has a grayish colored surface coating, if so it would be galvanized. If it is polished, it could be a ferritic stainless steel.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
S.
Corrosion Protection & Corrosion Control
