Button Mapping in NX5
I'm using a Spaceball 5000 and when I use the button map in NX it seems the functions are not working.
If however I go back to the 3D Con. panel I can map them and get them to work there.
We are working on 64 bit platform using XP PRO 64
Are there some settings to enable the button mapping tool?
RE: Button Mapping in NX5
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Best regards
Hudson
Doc
http://www.goodrich.com
First I had the IT reinstall the drivers which helped. And instead of dragging the function to the buttons Which I had read some where. I right click function and assign and save plus everytime you go into button mapper make sure to click ok and not window close button following that everything and now things are working fine.
Doc
