Hertz contact problem
Hi!
Im' trying to simulate Hertz contact in Abaqus. The model contains cylinder which lies on the rigid surface.The cylinder is under gravity load. I've got a little question. The cylinder will undergo the deformation after the influence of the gravity. Where Can I find in results size of a contact area?
RE: Hertz contact problem
You can plot CPRESS
corus
