Complex 3D Contact Body Movement Definition
Hi Guys,
I am new to this forum so apologies if this question has already been covered. I had a quick look over the old threads but didn't find an answer...
I would like to define the complex movement of a 3D rigid contact body in Marc/Mentat. The part I am modelling is a grommet similar to that found around a car gearstick. I have 5 axes in Catia V5 which define the "worstcase" positions of the shaft. Unfortunately these axes do not share a common rotation axis. How can I define this motion in Mentat?
I have been trying to work this through myself and it seems I need to define each "axis to axis" movement as 3 rotation/translation functions based on the primary axis. Sounds simple enough, but how??? I can't even define the tables to get two lines to translate/rotate on to each other in 2D...
I would be VERY grateful if someone could shed some light on this problem. If there is a makro or script to produce the necessary graphs, that would be fantastic!
Many thanks, Stuart
www.sgatdesign.com
Many thanks, Stuart
www.sgatdesign.com
RE: Complex 3D Contact Body Movement Definition
