Removing references
Removing references
I have an assy & some parts were deleted from the assy. The parts may have been deleted from windows explorer but are still associated with the assy. The parts are not in the assy but when I open the assy it SW states it can not find the part, do I want to search for it myself.
I can not figure out how to remove these parts fully from the assy so SW does not ask me to find the parts which do not exist anymore. In the assy references I can see the parts but can't remove them.
Any ideas? SW2007 sp2.2
RE: Removing references
This is real "seat of pants" solution and hopefully you will find something better:
Make a dummy part. Give it a name and save it.
Open the assembly and every time it asks for an unfound part, direct it to the dummy part. Then delete all of the dummy parts from the assembly after it opens.
Now that I removed from the sub assys, it fixed the problem.
thanks to all
Eric
