Surfcam Layers
Surfcam Layers
Surfcam Layers
This is a little bit of a cross-forum question, but I'm having issues with seeing exported layers when opening/converting a dxf in surfcam.
I create the original drawing in Solidworks and create the different layers.  I save it as a dxf and open the dxf in DwgEditor and the layers are there.  However, when the same dxf file is opened/converted in surfcam, the layers aren't there.
Any ideas or suggestions?
Thanks!
RE: Surfcam Layers
Check the Surfcam forum at cnczone.com - you'll find help there.  I'm stuck at version 2001 since the company stopped maintenance.
