ANSYS modal analysis
Hello all,
I am currently working on a modal analysis of an electrical motor IN USE.
I can only use ANSYS to do it, what is the best way to do that?
I had a look to ANSYS'help, but only found modal static analysis (only possible loads=displacement with the module "modal analysis"...) or very basic examples of dynamic mass-spring system with the module "Harmonic".
I got an ProEngineer model of the motor, could I use it in ANSYS ? or should I model it directly in ANSYS in a basic way ?
Thanks for your answers, & sorry for my poor skill in English ;)
Thomas
Thomas
RE: ANSYS modal analysis
http://www.eng-tips.com/threadminder.cfm?pid=569
Tobalcane
"If you avoid failure, you also avoid success."
