PROFILE TOLERANCE OF SPLINES - CLASS 4
I'm looking thru the ANSI B92.1 spline book (table #3) and trying to find out if the profile tolerance needs to be compensated as the tooth thickness or space width.  I believe that the book reads that the multiplication factor only applies to the CTT or CSW.  Can anybody confirm this?  I also need the Para number and page if possible.
Thanks to all.
RE: PROFILE TOLERANCE OF SPLINES - CLASS 4
wallyd999 (Aerospace) 14 Mar 08 14:01
Thanks to all.
Thanks.
This post was a repeat which you are the 1st to respond.
