Laser cutting aircraft brake parts... HAZ?
My company is looking to manufacture aircraft brake parts, the part I'm discussing here is the brake rotor. The rotor has ten segments that attach to each other like jig saw pieces. When the rotor is assembled the pieces simply slide together on a table. Each rotor segment has to be cut to within +- .002". We know other companies are manufacturing aircraft brakes using laser cutting, which seems to be much cheaper than using a water jet that will hold the required tolerance. So I'm looking for ways to both minimize the effect of the HAZ and explain it away for part certification. These parts are made of AMS 6385 (17-22). I talked to one manufacturer that says they heat treat after the part is cut, but we were worried about warping if we heat treat after the part is cut (it will also be ground to the correct thickness by almost a tenth), and will heat treating in this order completly remove the affect of the HAZ? This part will be quenched, tempered and through hardened to 23 HRC. Any thought are greatly appreciated.
RE: Laser cutting aircraft brake parts... HAZ?
HRc 23 is not that hard. particularaly for a low alloy composition like the AMS 6385. (that took a bit of searching, spec is linked below.)
There are other types of processes that may be able to produce a good part. there are blended water/laser methods, wire edm if theyre flat (will still have HAZ's just lots smaller).
Even (if they're not too thick) stamping might be an option.
ht
Nick
I love materials science!
