23MnNiCrMo52 DIN17115
Can anyone point me in the direction of a equivalent of the above material spec please?
RE: 23MnNiCrMo52 DIN17115
Looks like an SAE 8620.
There is no exact USA equivalent, since this standard (DIN 17115) is for welded chain links.  The grade 23MnNiCrMo 5 2 (1.6541) is closer to 8720 than 8620, but neither of these has as much Mn or allows as much Cr at the upper end.  A non-standard grade 8722 would be even closer.
TVP;
Despite the fact that there is no equivalent, for welded chain link application, I would probably go with the 8620.
