hole callouts on sheetmetal drawings
Just came across something really bizarre. Using SW2008 SP3.0. I sometimes edit the hole callout text in drawings (not the value itself, just adding/removing text). Solidworks is not letting me edit the hole callouts at all. It pops up the standard warning message about breaking the link with the model, but even if i say "yes", it doesn't work. I can type in the property box but nothing changes in the callout. And this only seems to be a problem on sheetmetal parts. I tried some regular solid parts and i can edit their hole callouts fine. Anyone with similar experience?
