Creating material
Creating material
Hello everyone,
I was wondering if anybody can help me?
I am trying to create a material, and unable to find the relevant information in order to do so.
Ther materials are:
Low density foam 24kg/m³
Medium density foam 104kg/m³
High density foam 144kg/m³
Any help would be greatly appreciated.
Ther materials are:
RE: Creating material
http://www.matweb.com/index.aspx
For more refined editing, once you create the material, you can edit the materials library file directly with notepad.
If you do want a custom image, then yes, you'll need to make/find one to apply.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Thanks again
If you find all of the material properties, and correct material name, send them to me and I can add them to my database.
The trouble I have with a lot of materials is I can't find the correct props.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
http://www.amconvas.com/materialscase.html
These are three materials not in your data base that I have used. Take them for what they are worth (i.e, double check before you build something that someone's life will depend on!). Materials are Zinc-Aluminum Aly ZA-12, Aluminum-Magnesium Aly 535.0 and Beralcast 363 Beryllium-Aluminum Aly. data is from Matweb or mfr site.
Harold
SW2008 SP3.0 OPW2008 SP0.1 Win XP Pro 2002 SP2
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
I have a new material that can be added too..I'll email it separately to you.
Matt Lorono
Silicon Valley, CA
Chris
AutoCAD 06/08
