Object display issues in Femap
I am a new femap user comming from Ansys and I had a question about the way a part displays.  I have imported a solid model assembly in from UGS and would like to add connections between the parts.
What I am interested in know is when I click on a part in the Model Info >> Geometry menu, when i click on a part like "2..Part:2" how do i make it stand out from the other parts.  In ansys, it would turn green.
Also related to this, when I select a connection from the Model Info >> Connectors menu, how do I get it to highlight to two parts when I click on "2..Region 3-1" so I can see the contact region?  In ansys these two parts would be solid and everything else would go to a dim profile.
Thank you,
Joe
RE: Object display issues in Femap
So I have been playing with this a little more and can clarify my question.  When I click on a connector region, there is an option to show the master or slave.  Is there a way that I can enable this to be the default view when i select the region ratehr then having to right click and select one or the other?
Also I have noticed that when I click on a part in the model window, and select activate, it appears in blue text on the Geometry menu.  Is there a way to make this work the otehr way, so that it highlights the part when i select it from the geometry menu?
joe
Thank you, i think i figured it out, it would appear that there is a show highlighted button at the top of the Model Info bar.
Joe
