Electrostatic analysis on WB. Volt loads.
I always have used Ansys Classic, however, I had to change to workbench. I can run most of the analysis that I was used to run on Ansys Classic, the electrostactic analysis however, is not shown on environmental map. I could find only the Magnetostatics option (that's the closest environment to Emag that I could find). I would like to apply some VOLT boundary conditions. However this kind of load is not available on magnetostatics environment. I appreciate any help I could get.
Thanks.
Thanks.
