So what's this new release all about then?
Does anyone know what the release of V21 is all about? I've been able to find out very little from our supplier, although we've been invited to a demo in June...
The most I've found out is on this reseller site - http://www.solidapps.co.uk/UserGroupMeetings.html which isn't a lot, but to quote them 'Countdown to the 3D CAD Revolution, when a new age in CAD software will be born.'
Anyone got any info?
Cheers,
M
Cheers,
M
RE: So what's this new release all about then?
KENAT, probably the least qualified checker you'll ever meet...
From what she told me the interface is very different, she mentioned that it did not have tool bars per say but when you hovered over a feature it gave you only the options you can do to that feature if that makes sense.
Now I dont know if I understood this right or not though.
She also stated that they believe this version of Edge will be upto 2 years ahead of the compition so they have a lot to live upto.
Also I was told that there would be no need to upgrade hardware if its a good spec as they have designed it around using the recommened spec of Version 20.
But who knows as they are very secretive about this version.
On another note, if they are changing the interface... are they going to provide free training to all that have been/are going on courses this year? Our company is investing a lot of money next month on training the whole department, where half have not used 3D before. It'll be interesting to see how that half would cope with suddenly having all their buttons taken away(!) I wonder if there will be a 'classic' mode so all the buttons are there :)
M
Let's hope they don't break it just for the sake of being different to the competition. Hopefully it's an enhancement to the present direct editing, and a more refined way of getting at the parameters/properties of a feature.
I recently had a go with the new SpaceClaim package.
That works on a direct editing style and there is no history tree, much the same as in CoCreate One-Space. If you want to move or rotate a face you just drag it or input a distance. There is some REALLY clever stuff but I found it difficult to control things - probably because I didn't get into the system enough.
Have a look at this video -
http:/
bc
bc
http://w
Solid Edge V20 SP4 on WinXP SP2
I just hope that like Autocad 2009, you'll have an option in SE to go back to the classic interface.
And I hope that all that hype will not amount only to this UI change...
That would be quite embarassing after the 'hype' building up to this release, considering what they say at the link Toffeet has posted - "Are you ready for a product design experience that's up to 100 times faster?"
Wow! a bold claim (but they will never be able to speeed up the problem of getting information from suppliers, and getting managers to make a decision !)
I think it's possibly a change to the way of working and interacting with model data. As suggested earlier, maybe more of a 'direct modelling' approach.
One thing I would like to see is a merging of model types, especially part and sheet metal - you should really not have to decide at an early stage what manufacturing process you are going to use.
Some systems only have one model type, then you just decide whether to do part modelling or add components to make an assembly.
I would also like to see multiple bodies in one file.
Can't wait to see it.
bc
Question 1:
When did Development start on this revolutionary release? Was it done in the same time frame as prior releases or has this been in the works for some time?
Answer 1:
Multi-year effort.
Question 2:
Did Siemens funding help drive this release? One of the big questions has been the impact Siemens would have on Solid Edge.
Answer 2:
Yes.
Remember their big thing on marketing etc is to win over people still doing 2D. They seem less concerned over getting people to move from other 3D systems to SE.
http://
bc.
CAD2 Imagine Workstation
2.4GHz Core2 Quad
4GB RAM
Quadro FX4600
24" Iiyama widescreen
Its good to see Solid Edge doing some marketing, perhaps it will start to shake off the 'best 3D CAD package you'll never use' moniker.
http://
Having never tried Spaceclaim I can't really comment on that, but maybe some else in this excellent forum can.
However, with this "new" technology in SE it appears you can have a mix of direct editing and parametric etc.
Although I can see uses for direct editing of dumb imported models, I don't like the idea of mixing it with parametric profiles etc. What happens when you move a face that has a sketch dimension controlling its position ?
bc.
2.4GHz Core2 Quad
4GB RAM
Quadro FX4600
The technology is significantly different. SpaceClaim for example uses ACIS and doesn't have a constraint solving engine. Synchronous Technology is actually a layer (shared by NX and SE and not available externally) built upon D-Cubed and Parasolid and both leveraging them to the hilt and adding new technologies as well.
