Vertical text dimensions & horizontal text dimensions on same drawing.
Does anyone know how to rotate text dimnesions in Wildfire 2.0, so you can have both vertical text dimensions and horizontal text dimensions on the same drawing?
RE: Vertical text dimensions & horizontal text dimensions on same drawing.
Set the drawing .dtl option text_orientation.  We use iso_parallel_diam_horiz.
