Question about single V joint welding
What is the maximum thickness we can used for single V joint welding.
Plate thickness: 40mm, 60mm.
RE: Question about single V joint welding
What is the application? There are no specific requirements related to material thickness where you are mandated to switch from single vee to a double vee full penetration weld joint detail. A double vee weld joint can provide reduced distortion during and after welding depending on sequence of welds and can allow back grinding to assure full penetration. A single vee groove can be limited by access to the root resulting in excessive weld deposits, depending on the weld process. Electroslag welds use a square groove weld detail that can extend for 6" in depth with weld deposition performed from one side (similar to a vee groove).
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
Steve Jones
http://www.pdo.co.om/pdoweb/
