Lisp routine modify?
I have a little bit of experience in lisp programming, but still feel way over my head, even on the easy things.
We have a lisp routine that automates some things with blocks for us, that when we run it, says "Select block" but I am trying to find a way to modify it so that I can type the block name in instead of selecting it.  It's a big time saver on some of the larger drawings so I don't have to filter out the block by name, and zoom in to find it.
Is that something simple to do?
RE: Lisp routine modify?
Yes -  if you don't need to operate on a particular block insert.  The current "select block" probably just extracts the block name anyway.
You could have a command line option, like;
Select block /Type:
so if you hit "T" then it would prompt you for block name.
