ASME II-D Ed 2007
ASME II-D Ed 2007
ASME II-D Ed 2007
I would like to get the stress tables used in ASME Sec 2 part D edition 2007 in MS-Excel (or equivalent spreadsheet format). Either metric units or US customary units would suffice.
Can anybody send me link as to where I can get the same?
Thanks in advance.
reg,
Jehan
RE: ASME II-D Ed 2007
If you have an official copy of the code, you may be able to access the electronic stress tables - http://www.est.asme.org/knovel2/asme/default.jsp .
If you don't have your username and password for the EST, you may be able to follow the contact info on the website to get that set up.  Your employer may already have this info...
Let us know how this works out for you.
If you are looking for the Div 2 stress values, you can find them at http://www.asme.org/Codes/Publications/Section_IID_2.cfm
