Can someone help me find out Socket Fitting for under pressure 52MPa?
For use of welded connection to Wellhead API 10,000 Flange, what pipe 2" or 3" NPS (both in ASME and CSA) could be used for under pressure 52,000KPag@-45 C?
What pipe fitting 3/4" NPS threaded or socket for use on the 2" or 3" run under that high pressure?
Thanks.
