Effective area of a circular foundation
As you know, load eccentricity decreases the ultimate vertical load that a footing can withstand. This effect is accounted for in bearing capacity analysis by reducing the effective area of the footing.
Does anyone know a solution for effective area in circular bases?
There is something in API PR2A-WSD, section C6.13, whch seems to be wrong!!
RE: Effective area of a circular foundation
mahisub,
Suggest that you make simplified and/or conservative assumptions to extend the theory with respect to rectangular/square footings to a circular area.
Jeff
why not design using actual dimensions. Apply moment and work out + and - pressures due to moment. Then dimension to eliminate negative values. i.e. tension on any side.
With the eccentricity the effective shape goes from a circle to a football.  Just a matter of geometry.
f-d
¡papá gordo ain’t no madre flaca!
(Mark?) Fintel's Concrete Structures Handbook treats this problem exactly.  No guessing required.
Joe Tank
JoeTank:  Good for you - yes, it is Mark.  Section 5.2 for what he is looking at.  Sadly, my book had a printing error for Figure 5-5 "Bearing Pressure distribution under eceentric loading" - (Light print).
