Auxiliary View Arrow Text Position
I have an auxiliary view where the arrow text is a double letter, in this case shown as 'PP'. The text is interfering with the arrow if the arrow is in the 180 to 270 deg position (from 12 o'clock)see attachment. Can anyone help re-position the text.
RE: Auxiliary View Arrow Text Position
Just select the text and drag to where needed.
cheers
Aux view arrow letters can't be dragged (SW 2007).  Frustrating.
You can change the font spacing, which changes the letter distance from the arrow.
Document properties --> Annotation font --> View arrow, set font height to "units" and adjust the "space" parameter.
Thanks Tick, I did not know that.
Another workaround would be to use a regular Section View where the Annotation can be moved. The section view can be created using a line drawn parallel to the edge that would have been used for the Auxiliary View.
cheers
or, when creating the view, don't have it add the text. Add the text manually later.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
