Concatenate two listboxes in a textbox
Just wondering if someone can help with the macro to Concatenate two listboxes in a textbox. I have tried but I can't figure it out.
I have two listboxes filled with selections from BTC sheet, these listboxes are on a userform. The two are exactly alike since it is designed for rev changes.
I have a textbox that already is running if you type old and new rev, but want to make it so click, click and your done instead of typing
Your help is most appreciated
RE: Concatenate two listboxes in a textbox
I'll guess that each of the list boxes has a list of items in it, and you want to combine one from list 1 and one from list 2 into a text box?
If so, something like:
CODE
TextBox1.Value = ListBox1.Value
End Sub
Private Sub ListBox2_DblClick(ByVal cancel As MSForms.ReturnBoolean)
TextBox1.Value = TextBox1.Value & " " & ListBox2.Value
End Sub
CODE
TextBox1.Text = "" & ListBox1.Text
End Sub
Private Sub ListBox2_Click()
With TextBox1
.Text = .Text & ListBox2.Text
End With
End Sub
you've called your listboxes
ListBox1 & ListBox2
you've called your textbox
Textbox1
So what I am trying to achieve is the user clicks on the selection in LB1 and one in LB2 so the textbox shows the choices Concatenated. e.g. A / E. I already have the textbox coded to the placement on the sheet. If you need to see the lengthy code I can post it.
Thanks for the help
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Dim UForm As UserForm33
Dim Sel_Row As Long
Dim Cont_Item As MSForms.Control
Dim Col_Name As String
Dim ListBox_Item As MSForms.ListBox
Dim Cnt1 As Integer
Dim Cnt2 As Integer
Dim Flag
Cancel = True
Set UForm = New UserForm33
Sel_Row = Target.Row
'POPULATE THE USERFORM FIELDS
'TEXT BOXES
UForm.TextBox4.Value = Me.Range("A" & Sel_Row).Value
UForm.TextBox2.Value = Me.Range("B" & Sel_Row).Value
UForm.TextBox5.Value = Me.Range("F" & Sel_Row).Value
UForm.TextBox6.Value = Me.Range("G" & Sel_Row).Value
UForm.TextBox7.Value = Me.Range("N" & Sel_Row).Value
UForm.TextBox3.Value = Me.Range("C" & Sel_Row).Value
UForm.TextBox10.Value = Me.Range("H" & Sel_Row).Value
' OPTION BUTTONS
'POPULATE LIST BOXES
UForm.ListBox1.List = Sheet4.Range("E2:E11").Value
UForm.ListBox4.List = Sheet4.Range("C2:C5").Value
UForm.ListBox5.List = Sheet4.Range("G2:G8").Value
UForm.ListBox6.List = Sheet4.Range("M2:M4").Value
UForm.ListBox7.List = Sheet4.Range("O2:O8").Value
UForm.ListBox8.List = Sheet4.Range("P2:P8").Value
'SELECT IN LISTS
For Each Cont_Item In UForm.Controls
If TypeName(Cont_Item) = "ListBox" Then
Set ListBox_Item = Cont_Item
Col_Name = ""
Select Case Cont_Item.Name
Case UForm.ListBox1.Name
Col_Name = "O"
Case UForm.ListBox4.Name
Col_Name = "E"
Case UForm.ListBox5.Name
Col_Name = "D"
End Select
End If
Next Cont_Item
Manual_Quit = False
UForm.Show
If Manual_Quit Then
Exit Sub
End If
'POPULATE FROM USERFORM
'TEXT BOXES
Me.Range("A" & Sel_Row).Value = UForm.TextBox4.Value
Me.Range("B" & Sel_Row).Value = UForm.TextBox2.Value
Me.Range("F" & Sel_Row).Value = UForm.TextBox5.Value
Me.Range("G" & Sel_Row).Value = UForm.TextBox6.Value
Me.Range("N" & Sel_Row).Value = UForm.TextBox7.Value
Me.Range("C" & Sel_Row).Value = UForm.TextBox3.Value
Me.Range("H" & Sel_Row).Value = UForm.TextBox10.Value
'OPTION BUTTONS
'LIST BOXES
Col_Name = ""
Col_Name = "O"
Col_Name = "E"
Col_Name = "D"
Case UForm.ListBox6.Name
Col_Name = "L"
Case UForm.ListBox7.Name
Col_Name = "H"
Case UForm.ListBox8.Name
Col_Name = "H"
End Select
' Deleting the 9 rows below,,, will not give me an error... however, List boxes are not being entered into the cells
For Cnt2 = 0 To ListBox_Item.ListCount - 1
If ListBox_Item.Selected(Cnt2) = True Then
Me.Range(Col_Name & Sel_Row).Value = ListBox_Item.List(Cnt2)
Exit For
End If
Next Cnt2
Set ListBox_Item = Nothing
End If
Next Cont_Item
Set UForm = Nothing
End Sub
