link for the step files viewer
hi
I just need to send some files to one of my purchasing guy.He does not have any 3d software.I am planning to send him step files.But any of you guys are aware of any viewer available in the web for free so that he can see the step files or can you suggest me any of the work around.
Thanks in advance
Thanks in advance
RE: link for the step files viewer
but i need to send them as individula files and not as assemby, and in catia we can save as 3dxml only for assy
You can change the 3DXML extension in zip, unzip that file in a folder and you will have all parts in that assy individually saved as 3DXML. Its not so hard to insert your parts in an assy...and save as 3DXML...
Fernando
thanks ferdo for ur reply,
can you please still elaborate ur procedure with some example
thanks
I suppose that you don't want your purchaser to see your assy, isn't it?
In addition, these files can't be used to recreate the initial 3D model, you can't do nothing with them (measure or whatever) its just for presentation....
You can download the 3DXML viewer from DS website.
Fernando
ou are genious man,what exp.do you have in catia
hats off,
thank you very much
am using r16
any way the issue was solved
Derek
Fernando
