Use of antifoulants in catalytic reactors
I would like to know if there is any good experience with the use of antifoulants to remove gums from the top bed of a desulfurization reactor. When cracked feedstocks are exposed to air (sometimes you have to do it during non routine operations)gums are formed in the top section of the reactor, which increase the pressure drop across the bed.
If there any other procedure that can be applied in these situations?
Oilman
RE: Use of antifoulants in catalytic reactors
Dear oilman
I suggest you contact Exxon-Nalco for gum inhibitors,and
Foster Wheeler Q&A site too..
Regards  Whylie
