Two way PT Slab - Concentration of Bottom Steel at columns
In plan review on a few projects, I have noticed that some two way P/T Slabs specify a group of bottom bars centered over the columns that is on par with the total amount of top steel added above the column. I am a little bit embarassed, but I am not sure what this bottom steel is for. On three separate projects looked at over the last couple years, I have seen anywhere from (3) #5 by 9'-0" long to (8) #6 x 12'-0" long placed directly over the column in each direction.
Any idea on what code provision requires this rebar? Is it for transferring the unbalanced moments in the slab into the column via flexure? A seismic Requirement for continuity? The amount of rebar placed here seems somewhat random when looking from project to project, many times they just pick an amount of rebar and use it for every column on the job.
Thanks for any input on this . . . I guess you learn something new every day.
RE: Two way PT Slab - Concentration of Bottom Steel at columns
I am guessing it is a seismic requirement, but I can't seem to find it anywhere.
AUCE98
