ASCE 7-5 seismic question
In ASCE 7-05 section 12.4.3, it talkes about including the seismic overstrength factor where conditions require it.  When is that factor specifically required, and when do you use the normal seismic equations shown in section 12.4.2?
RE: ASCE 7-5 seismic question
Here are some threads on that subject:
thread487-204811: Metal Building Foundation Design with Overstrength Factor
thread172-185459: Base Plate Design in Seismic Design Category D
thread726-126245: when do I use the ASCE7 Special seimic load?
thread487-205844: IBC 2006/ASCE 7-05 Load combo question
thread176-140534: Special seismic load combinations
The overstrength combinations are sprinkled throughout the codes, specifically they are used to beef up those elements or connections that have brittle failure modes vs. ductile modes.  They attempt to ensure that the weak link in the chain is a ductile failure that will use up the energy and avoid catastrophic collapse.
You have to read through all the specific design requirements in the code to find where they are required.
