trussed tower wind loads - epsilon (ratio of solid to gross area)
This is in regards to the calculation of Cf (see Fig. 6-22 in ASCE 7-02) for trussed towers using the following formula:
Cf = 4.0e^2 - 5.9e + 4.0, where e is epsilon
Max Cf = 2.1 when e=1
~Min Cf = 3.94 when e=0.01
As epsilon (ratio of solid to gross area) increases, Cf descreases. According to this, as the element in question becomes more "solid", Cf, and therefore the wind force F in Eq. 6-25 decreases. This seems counterintuitive to me, since the more "solid" something is, the more surface area it has for wind pressure to act upon. What am I missing here?
RE: trussed tower wind loads - epsilon (ratio of solid to gross area)
