How much eccentricity for a buckling load?
As you know, there are a number of semi-empirical formulas for buckling in columns in the intermediate length range. One of these is the J.B. Johnson Formula. I would like to know how much eccentricity (e) you consider for a column with length L?
I am looking for a realistic e/L ratio (rule of thumb which is not too much conservative).
FYI, I found in different stress reports ratios from 1/400 to 1/100.
A.A.Y.
RE: How much eccentricity for a buckling load?
Well, it depends...
what is the specific application?
how is the load introduced at the ends?
what are the boundary conditions?
how is the part fabricated?
I have seen analysis done with no eccentricity (offset) all the way up to applying a momeent equal to 10% of P.
Hi SWComposites,
I am sorry, I did not give you enough details. Following are my responses:
what is the specific application? Landing Gear Structures
how is the load introduced at the ends? A uniform column is subjected to a concentrated axial load.
what are the boundary conditions? Pinned Ends
how is the part fabricated? Machined Parts
A.A.Y.
Well in that case, the landing gear analyses that I have seen have applied a moment equal to 10% P to account for misalignment and eccentricity, and analyzed the part as a beam column.
Thank you SWComposites, for our application it seems to be a reasonable approach.
A.A.Y.
