Film Coefficients for Internal Pipe Flow
I am trying to find a range of values for film coefficients on the internal of an 8" pipe. Problem is, I don't (as yet) have much info on the fluid other than it is mixed hydrocarbons, ~950°F, with a flow rate in the range of 147000 lbs/hr.
I just don't have a good feel for what the range of coefficients could be...what value is to high, etc. As it is that flow rate seems extremely high to me in terms of fluid velocity, but that is what I have for now.
While I know the relations to calculate the Nu number, I don't have a feel for the constants that go into calculating the PR and Re numbers.
Thanks in advance.
Thanks in advance.
RE: Film Coefficients for Internal Pipe Flow
Good luck,
Latexman
Good luck,
Latexman
