Max distance between nozzles on horizontal vessel
How can I determine the maximum distance between two nozzles on a horizontal vessel allowed by code?
1800mm inside diameter with 20mm wt.
RE: Max distance between nozzles on horizontal vessel
There is no maximum in the code.
The maximum will depend on the physical size of the vessel and nozzles and where your connectiing pipework is.
However, if I read correctly, you are Texas Engineer, hence you're looking for the biggest possible distance between nozzles;- the code does not restrict the distance between nozzles, other than practical limits, like border line between Texas and the neighbouring countries. It also depends of the size/length of your vessel, the available plant plot. If you need to locate the nozzles on the shell of a horizontal vessel, you could place them at the opposite ends of the vessel, better still one in the top, the other on the bottom. I suggest to keep some 1.25-1.5" distance between the nozzle weld and the dished end's circ weld (please note that you can override this advice in some circumstances and weld the nozzle on the head circumferential weld, to extend the distance with a hefty 2.5" or even cross the weld into the dished end straight flange area, if applicable).
I would also suggest to have another look at your post and try to re-phrase your question, since it sounds a bit funny.
cheers,
gr2vessels
BS 5500 - Para 3.5.4.2 b.
2) Oblique nozzles
The nozzle shall be of circular cross-section and the angle between the axis of the nozzle and a line
normal to the shell surface shall not exceed 50°.
As far as I am aware ASME VII has no limit and will accept tangential (hillside) nozzles
I'm sure someone will correct me if I'm wrong
cheers,
gr2vessels
