PCI Converter 2.2 to 2.1
I am looking for a converter that will convert a PCI 2.2 card to a PCI 2.1, so that I can plug it into a PCI 2.1 compatible slot.
Does such a thing exist?
This is what each looks like:
PCI 2.2 : http ://www.all oy.com.au/ images/ALL OY-1440SC_ 500x500pix _LoRes.jpg
PCI 2.1: http://www.maplin.co.uk/images/Full/ry73.jpg
Please help me, Thank you so much!
PCI 2.2 : http
RE: PCI Converter 2.2 to 2.1
One card is 3.3v the other is 5v
See http:
This is what the pc spec's say
PCI Slot
- 1 x 32Bit PCI 2.1 Compliant card up to 24cm
- PCI 2.1 Compliant
- Supports 3.3V and 5V PCI cards
So if 5v=2.2, then 2.2 should work>?
From the link:
"PCI 2.2 will do 5v or 3.3v, whereas 2.1 will only do 5v... per spec requirements
I know many will read this and say "AH! But PCI 2.1 WILL run 3.3v!!!" This is true to a point- the enabling of the 3.3v rail was encouraged in the PCI 2.1 spec. It wasnt until 2.2 that it was required. So, many MB manufacturers opted not to."
So basically if the motherboard states 3.3v or 5v then it should be fine.
