Beam Deflection
Beam Deflection
Beam Deflection
I am new to usiing Roark's Formulas for Stress and Strain and need some help.  I have a copy of the 7th edition.  My question is how do use the table 8.1, 2e (simply support beam with uniform distributed load across beam) to find the deflection at any point x along the beam?  Thanks
RE: Beam Deflection
I am looking at the same info in the fifth edition...  Better be careful here - this table is addressing axial and bending stresses combined.  Read the application on page 147 and 152 with following examples.  Do you have that, or just simple bending due to a uniform, or uniformly varying load?  Also, note the link back to table 3 on page 100, situation 2e.
Mike McCann
McCann Engineering
RE: Beam Deflection
msquared48,  I just have simple blend if a uniform distributed load accross the entire beam.  The beam is L = 15 and I am interested in x = 10.
RE: Beam Deflection
i don't think roark includes generalised deflection data, only the maximum deflection.  get out a piece of paper and solve it from 1st principles ... M(x) ... integrate for v(x), integrate for d(x) ... solve integration constants from boundary conditions ... it ain't rocket science !
RE: Beam Deflection
Back at the first of the table are the general equations for deflections, and then in the particular load case, it gives you specific factors for those equations.  Quite a few of the tables are presented in this way
RE: Beam Deflection
If I understand you correctly, who needs Roark!
The AISC Manual of Steel Construction gives beam diagrams and formulas under the "Beam" tab. For a simple beam with uniformly distributed load the formula for deflection is
Delta(x)= (wx/24EI)(l^3-2lx^2+x^3)
where "x"=distance along the beam, "w" is the load/ft, and "l" is the beam length.
RE: Beam Deflection
True, but it gets much handier for other cases.
RE: Beam Deflection
Who the heck is Roark?
RE: Beam Deflection
He was the original author of this reference, in 1938.  So I suppose he is no longer with us, but others have picked up his work and kept it current.
Anybody have a biographical reference?
RE: Beam Deflection
Not too much online.  A couple of other books of which he was author or co-author pop up.  And from www.findagrave.com, the following:
Raymond J. Roark
Born Jul. 25, 1890, Greenville, Kentucky
Died Jun. 1, 1966, Madison, Wisconsin, USA
Professor of Engineering,University of Wisconsin
Son of Mary (Creagon) Roark.
Husband of Margaret M. (Mott) Roark.
Buried in Forest Hill Cemetery, Madison, Wisconsin
