how to choose materials for the internal parts of the submerge pump
I would like to know how to choose materials for the internal parts of the submerge pump.
this pump will be use in the sea (salt problem)
please help
thank you
please help
thank you
RE: how to choose materials for the internal parts of the submerge pump
Are you talking about an electric submersible pump or just a submerged wetend, also - what size pump unit are you considering.
Steve Jones
http://www.pdo.co.om/pdoweb/
I think you will find for seawater that the salt content is not the problem; it’s the oxygenated water. I would suggest duplex stainless or Nichol – aluminum – bronze impellers.
D23
If cost is not the most important factor, Ni-Al-Bronze material is perfect. It was commonly used on marine fire-fighting ships.
