CATIA: File not could be found
I open a CATProduct and CATIA send me a message : " The files in the following list could not be found or contain the wrong information for the active document...".
The problem is these files weren't in the location where is shown by CATIA message, and I've added the good location of these files in CATIA configuration of Document.
Someone can tell what I have to do to open my CATProduct, please?
Thanks in advance.
Hieu TRAN
Thanks in advance.
Hieu TRAN
RE: CATIA: File not could be found
If you already put the correct path for the new location of the files and CATIA its not loading your parts, that means you have a problem with UUID (see also http://www.eng-tips.com/faqs.cfm?fid=1318 ). So, one way to open those parts in your assy is to replace the old ones with the new ones and correct their position if necessary.
Fernando
