Prescribing a field and its flux on the same surface !
In the same analysis step I have a surfec on which the temperature is prescribed as a BC , on the same surface I applied loading : heat flux. I expected the job to be aborted as two fields that are cojugate are applied on the same surface,  but the job continued running. How that could happen.
Thanks for help
RE: Prescribing a field and its flux on the same surface !
A fix temperature and a fix heat flux could exist at the same time. For example, the sunlight shine on a plate on the ground. The plate may have a fix temperature such as 50 C, meanwhile it may transfer a fix heat flux such as 20 w/m2 into the ground beneath it.
Take care
jst9804
